JohnRa's avatar
JohnRa
Air Admittance Valve for RV
Hi, I think I've got a bad Air Admittance Valve under my kitchen sink. I went to Home Depot and bought a 1.5 - 2" AAV (the only one they had). The one in my KZ RV is much smaller.
Does anyone know what size it actually is, and where I could find a replacement for it?
  • I don't really have much room under the sink. the cheater valve actually hits the underside of the sink.
    Plus we've still got the smell from the sink. Boo. I think I may have to tear the drain apart and see if we've got something in there.
  • The threads on the AAV in our KZ are 1 1/2". If it really is smaller, just get an adapter.
    FWIW, I bought a replacement AAV for the one that failed in our KZ in less than year at Lowes. Well, that one failed too in a year.
    I would suggest getting a high quality Oatey AAV or equivalent. The quality one cost quite a bit more tho.
  • Chris, that's exactly what I needed. Appreciate your help!
  • I've seen both the large type you are talking bout and smaller ones. Try to see if they have this one (if it will display for you).
  • Be sure to remove the 2" adapter on the new one if you are talking about the thread size/diameter. The existing plumbing should have a 1-1/2" fitting.
    The valve diameter shouldn't matter.
  • The one I bought from Home Depot has a much larger diameter than the one I'm trying to replace.
  • JohnRa wrote:
    Sorry, I meant the diameter of the valve.
    The overall diameter doesn't effect the functionality. Are you having a fitment issue?
  • If you are talking about the threads, they should be 1 1/2" MPT.
    Last year my vendor had them for $2. This year, a new model, $20.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
