Inthecountry's avatar
Inthecountry
Air bag suspension for trucks question
I have a question on air bag suspension for my used Diesel F250 Super Duty truck.
I will be towing a three horse, living quarter trailer, gooseneck for the first time this year. Approx weight, no more than 12,000, most likely about 10,000 lbs.
Someone mentioned I need an air bag suspension and someone else said I didn't.
I'm not even sure what all they do, make a softer ride? Like shocks on a vehicle? Keep the gooseneck weight coming down so far?
Good idea to have them? And if so, which one is best, or the the best ones at the most reasonable price?
Thanks.
  • OK, now I'm confused, some are saying air bags are not correct, that they are air springs, but some are saying air bags. Are they one and the same?
  • Homer wrote:
    Those that say you cannot use them to increase your weight are correct. However, they make a hell of difference in how well that weight is handled.
    And...it's nice if you tow at night and you can level the truck to keep others from thinking your bright headlights are always on!
  • I can tell you I had airbags on my 2007 Cambria Class C. It made all the difference in the world when they were inflated properly. Proper inflation depends on how much weight is involved. With out the Air bags the rig was a bad handler. With 55 psi it handled like a dream. Those that say you cannot use them to increase your weight are correct. However, they make a hell of difference in how well that weight is handled.
  • Thanks. This is what comes up, still unsure about which one they are suggesting, but, can call and talk with them when they are open:
    FordF-2501999 to 2004 4WD4x4In-bed Hitch
    Pickup Truck Over 8500 GVWR
    Air Leveling
    Front
    RideRite 2223 - install manual
    2 Hours
    Spring: W21-760-6762
    Rear
    RideRite 2550 - install manual
    1.5
    No Drill Kit
    Spring: W21-760-6401
    Hybrid Suspension System
    Rear
    WorkRite 8613 - install manual
    1 Hour
    No Drill Kit
    Suggested Air Accessory
    Heavy Duty Air-Rite Air Control Systems
  • You might find this link helpful in understanding what benefits air springs provide. There's a bit of hype for their particular product there as well, but the basic facts are correct. As it happens, Firestone's Ride-Rite air springs are the ones I use and recommend when called for.
  • Is is not air bagmsuspension. It is air bags plane and simple. Rear air bags help level a loaded truck out when it is at or over its capacity to safely handle a load. They do not increade a trucks load carrying capacity. Depending on age and configuration, and passangers you may be OK or overloaded.
  • They increase the spring capacity to help keep the rear end from sagging under the load and improve handling under load. Technically, they're called "air springs", not "air bags". Properly inflated, they do make a difference on many setups. Without more specifics, there's no way to say how much they might help your setup.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
