wa8yxm
Feb 23, 2016Explorer III
Even then they had full sun, and still drew 30 amps, this means with their 700 AH of battery (3 times what my rig shipped with 1.5 what I have now) they only had less than 10 hours of run time.
A/C is more important at NIGHT when you are sleeping, NO solar then.
So yes, it can be done, No it is not practical AT THIS TIME, also that was a small A/C unit, Mine are bigger plus I have two of them.
It can be done, I know folks who do it. But in some conditions there is a better option. When last I was in the dessert I used a portable "Swamp Cooler" took a good 10 degrees off the bedroom. Added gallons of water to the air (I suffer from dry nose in the dessert) and only drew a few watts for the blower and water pump motors.. Alas, after several years the unit failed. But this puppy can run off the inverter no problem, even a 1500 watt is more than enough.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
