rvexodus
Jul 04, 2017Explorer
yillb wrote:MrWizard wrote:
he said the 15amp shore power and his solar are supplying charge to his 'Lithium battery bank
he is running the a/c from inverter power
I assume,, he has a deficit during the day using more power from batteries than is generated, and gets the batteries fully charged overnight ?
He's running TWO ac's from the inverter. I don't think it matters how many batteries you have, that's a lot of power. I'm pretty sure he's not even running the compressor, and it's just the fan as someone else pointed out. It happens on our venom toyhauler all the time.
No sir. Both compressors are running. When two ACs and the fridge are all running I’m showing an AC output of over 4500w on the victron and the power management system shows 35-45a power draw. I’ve also tested temps coming from the ducts in each room to ensure I’m getting 10-15deg diff between return register and vents. I really wish it were that simple. However, my inverts are capable of running two ACs with out a hitch of the lithium bank. If I have no solar and no shore power, I can only do that for a few hours before I’m out of juice but it’s absolutely possible.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
