maurice-r's avatar
maurice-r
Air Deflector Van + Cargo Trailer Fuel Improvement
This post is about my homebuilt air ramp or deflector and the fuel savings from it.
We are running a 2010 Chevy with 6.0 gasoline, 180k miles. Cargo trailer that I added a 9,000btu mini split, condenser mounted on front. Live in Indiana. Few years ago, step 1 was I built a "luggage rack" on the van, based on a commercial ladder rack that clips onto the gutter rail, but lowest possible to roof without paint damage.
Van not pulling a trailer gets about 13.5-14 MPG whether loaded or empty. All values as reported by Chevy dashboard, and backed up by occasional hand math from gas reciepts. Our first trip with van and cargo camper got us 6-7 MPG. About 70-75 MHP
Few years ago, we drove/towed to Yellowstone NP and Arches NP, with an 8' long air ramp made from OSB plywood and open sides. This got us about 7-8MPG and a few odd looks and questions.
This year I built an 8' long, 18" high to match the trailer, and enclosed sides air ramp, open at the back. We drove to San Deigo CA using the Flagstaff/ Yuma route. Going west empty, the best we got was 11.3 (dashboard). About 70-75 MPH. Going east, we were loaded with a family moving to Sommerset KY. From the picture, you might guess we were loaded heavy. For the eastbound trip, 65 MPH, we got 10.5 MPG.
The air ramp comes off with 6 bolts, and is stored in my barn.
My hope is that this info helps someone else. My numbers are not scientificly accurate.
  • If you google this subject you will find lots of equally unscientific studies. The mpg improvements with an air deflector are likely to be very small and only present at high speed driving. The extra weight is likely to yield negative results at lower speeds.
    Anyone interested can google testing by the YouTuber, Marion Blair. He found no benefit to offset the cost of installing a deflector. His studies seem to be a bit more scientific than most.
  • You will even get better economy and handling, if you would get your setup level, You need an equalizing hitch in the worst way.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
