pigman1
Jan 31, 2018Explorer
2chiefsRus wrote:I don't know if your Monaco is pre-wired for a trailer brake, but if it is, all you need to do is run the hot tattletale line through your 7 pin connector using the trailer brake wire. You then go under the dash and find the other end of that wire, stick a 12V LED on it and run the other end to the ground bar that all dash's have somewhere under there. No real wire running needed.Geeze wrote:2chiefsRus wrote:
Just had the Air Force One installed on our new Ford F-150. Love it so far except it is difficult to see the activation light in the windshield with the rear view camera. Does anyone have any suggestions on how to make the light more visible without running a line up to the motorhome dash? Thank you!
Demco, the maker of the Air Force One offers a wireless Coachlink. Haven't heard much about them but might be worth investigating.
Thanks for the reply. That is what Demco recommended but at $240 it seems a little steep. We'll probably end up running a light up to the dash
