older_fossil
Feb 16, 2018Explorer
pigman1 wrote:
I don't know if your Monaco is pre-wired for a trailer brake, but if it is, all you need to do is run the hot tattletale line through your 7 pin connector using the trailer brake wire. You then go under the dash and find the other end of that wire, stick a 12V LED on it and run the other end to the ground bar that all dash's have somewhere under there. No real wire running needed.
+1
This is exactly what we did with our AF-1 and our Tiffin Allegro Bus.
