pigman1
Feb 18, 2018Explorer
older_fossil wrote:Works great, doesn't it? This is the second Bus I did it to. One additional thing I did was to make a note of my "change" and put it into the Bus paperwork that will go to the next owner if and when you ever get rid of the beast. At least that way you'll save the poor guy a few hours tracing wires trying to find out what that extra red LED on the dash is for. Actually, All my systems documentation has been scanned to a laptop file and when I traded my 2008 Bus they got a CD with everything on it as well as the original paper copies. Some of the paper copies were getting quite dog eared.pigman1 wrote:
I don't know if your Monaco is pre-wired for a trailer brake, but if it is, all you need to do is run the hot tattletale line through your 7 pin connector using the trailer brake wire. You then go under the dash and find the other end of that wire, stick a 12V LED on it and run the other end to the ground bar that all dash's have somewhere under there. No real wire running needed.
+1
This is exactly what we did with our AF-1 and our Tiffin Allegro Bus.
