willald
Aug 11, 2014Explorer II
..Here's some other thoughts to ponder, to help in making your decision:
There are ZERO independent tests ever been done with any of these brake systems, to back up ANY claims of how much percentage one system may improve stopping over another.
Just because one manufacturer may claim 50% better stopping power or 30% better stopping power, does not mean ANY of it is necessarily true. There really is no way to know with certainty, if a Readybrake surge system will stop with any more or less stopping power than AF1 or any other system.
A surge system like Readybrake, indeed requires some 'push' on the tow bar before it engages. Is it enough to significantly affect braking performance, to the extent some proponents of AF1 system would have you believe? Here again, without any independent testing of the various systems, its impossible to say.
For all we know, the same would be true for AF1 and any other system (that some 'push' is applied to MH before toad brakes engage). It depends on several different factors. Sure, in THEORY, toad brakes powered directly off of the MH's air brakes should brake things a little more evenly. But, without putting a bunch of sensors of some kind on the tow bar, you really will never know. Every setup is different, and a zillion factors enter into just how braking will occur.
Is it really worth spending over $1000 more (plus additional installation) for a system that claims to have better performance, when there are ZERO independent tests done ANYWHERE to back such claims up? Thats a decision you have to make. I do know I'd have a really hard time spending that much more $$ without some pretty solid, significant proof that it will perform significantly better. But, thats just me.
Also, as already said, remember how simple the Readybrake is, and the fact that most of the things that may break or wear out on it, you will be able to buy parts at any hardware store for less than $20 to fix it. I doubt you'd be finding AF1 parts at a corner hardware store for less than $20.
And, one really nice thing about a mechanical system like Readybrake: You can inspect many of its components for wear and tear regularly, and fix worn parts before they become a problem. The same cannot be said for many components of a system like AF1.
Will
Will
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
