wca01
Aug 12, 2014Explorer
Scott,
I hope you will reconsider your decision about not having a breakaway system. I consider it to be a requirement for any supplemental MH/toad brake system. While a runaway toad is unlikely to be a hazard to you and yours, it is a serious hazard to others, both on the road and anywhere else near the breakaway. In addition, it gives you some defense if a breakaway causes any legal action from law enforcement or civil suit. The law isn’t entirely clear in every state, but many require a breakaway system for any towed trailer/car, etc. exceeding some weight limit, and any toad most likely exceeds most of those weight limits.
I also hope you will install a brake indicator on your MH dash operated from the toad BRAKE LIGHT SWITCH. When connected that way, you get an immediate indication when the supplemental brake system is braking or not braking. That not only warns you about system failure, but about operator error as well. I once failed to hook up the AF1 air hose and got an immediate “no brake action” warning before leaving the campsite.
Good Luck!
Wil
Good Luck!
Wil
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
