boingram wrote:
Hi all....got a new tv...2015 gmc 3500 denali crew duramax 4wd std bed srw.....anybody see a problem towing a 369rl solitude.
Here r rough numbers...trk rated at 11500 payload less trk of 7300 leaving 4200 payload. ..rear axle and tire specs confirm this. Dry wt 12500 loaded to 14000 for pin wt of 2800 leaves me 1400 payload left. Two of us..the dog...fuel totals 650. Looks like i am fine...anybody see a problem w these numbers...thx...bo
Using GM online weights calculator shows a 11500 GVWR 3500 SRW 7050 RAWR SLT 4wd std bed has a 4100+ lb payload which confirms your numbers.
The Solitude 369 RL shows a 16000 GVWR with a 3350 CCC and 12650 lb dry weight. Even at a 20 percent of the trailers full 16k GVWR which I doubt you will load it that heavy.
Either way the numbers look good as long as you don't load the truck with aux fuel tanks/other heavy unnecessary heavy junk.
