zackyboy3rs's avatar
zackyboy3rs
Andersen Hitch 3200 Rail version
I have the Revolution pin box. Will this work? Also, is it easy to hookup & unhook? Lastly, would I need the safety chains & are they easy to install on the rail version? Thanks.
  • You need to lock out the Revolution to use the Andersen. I have the rail mount and bought two anchors that also get pinned into the rails for the chains. Like was said earlier you have to raise the FW higher to hook up. I’ve only gotten to pull my FW once with the Andersen because we’re still getting snow.
  • You should go to a selling dealer for advice on your current set up before you buy anything. If the revolution is the sidewinder don`t even think about it until it`s been locked out.
  • Since no Andersen owners answered, I'll give my opinion. I think the rail version would be okay to use with the Revolution. You will have to raise the FW higher to hookup, and be more precise with alignment. Safety chains will be required in some areas, so best to have them installed. You may be able to hook them to the rails.
    Jerry
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 01, 2025
