portscanner's avatar
portscanner
Annoying Appliance Aggravates Anniversary Affair
We made it to our 30th!
We decided to run off and do one of our favorite activities - camping - to celebrate. Problem is, the first morning we got there we had a chill put on things. Looks like the thermocouple on our cold water heater* quit. (Fortunately we chose to go to a campground instead of boondocking and there were bath houses) The burner will light off and burn for about 15 seconds while the igniter continues to fire, then will shut down for 30 seconds. It will repeat that three times, then stay off until the switch is cycled.
I have decided to replace the water heater because:
1. it is 15 years old
2. I discovered the T&P valve 3 years ago would not open any more. I attempted to remove it and when I tried I started to crush it. Then I noticed the T&P valve would open again, so I stopped there.
3. There is all sorts of rust flakes falling off the outside of it (around the T&P valve and the annode)
I am guessing the water heater is a Suburban 5120A or equivalent based on appearance. Most all the labels on it are illegible and I have no documentation for it.
My question is should I just get another Suburban 5120A or is there something better I can get without breaking the bank? I expect that we will probably have this RV for at least another 5 years.
Your $0.02 would be appreciated!
* Yes, cold water heater. Why would you heat water that is already hot?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
