mowermech
Jun 08, 2016Explorer II
MFL wrote:downtheroad wrote:
Are you sure your Explorer is only rated to pull 2000 lbs?...seems really low.
Heck, our little Subaru has a much higher tow rating.
We pulled a Fleetwood Sea Pine pop up for years with our Explorer. It was a perfect match.
Re-check the numbers.
Yep, same engine, one Explorer 2K rating, other 5K rating, due to towing package. OP needs to upgrade to be similar to tow package. Likely gearing, cooling, and maybe hitch.
Jerry
Yep, the "tow package" consists of bolt-on parts. Install the necessary parts, and the tow rating increases. The parts needed MAY include a larger radiator, auxiliary transmission cooler, and a lower (numerically higher) differential ratio (such as changing from 3.5 to 3.73 or even 4.1). The hitch and the rear springs may also be different.
The "tow rating" is not chiseled in stone. It CAN be changed by installing the right parts, which are readily available from the vehicle manufacturer or from aftermarket sources.
All it takes is money...
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
