SeaCoast
Jun 09, 2016Explorer
badercubed wrote:SeaCoast wrote:Weird, ETrailer says that the Coil Sumosprings in the link will work with 2011 Explorers and they are pretty on.badercubed wrote:
My experience only.
We bought my wife a 2011 Explorer XLT (3.5L V6) with an aftermarket hitch that I purchased used directly from a Ford dealer. They told me the Class III aftermarket hitch made it rated for 4,000lbs. I used it to tow a 3 place v-nosed enclosed snowmobile trailer (with only two sleds in it) a few times which I would say was around 3,000lbs. Did it light the world on fire, no. But, the frontal area was obviously much larger than that of a popup of the same weight. I personally wouldn't hesitate.
Also, depending on how much is in the Explorer and what sag you see, you could add these for more rear-end support.
https://www.etrailer.com/Vehicle-Suspension/SuperSprings/CSS-1125R.html
Thanks, badercubed. Good to hear from first hand experience.
I tried the Super Springs website but they don't have an application for the 2011 Explorer.
Regardless, I think you will be fine with the popup, especially for weekend trips. If you are gonna go for a long time and are massively loaded then maybe you take the bigger vehicle, but I think you'll be pleased.
OK - sounds good! Thanks again and happy camping...
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
