Old-Biscuit
Oct 30, 2017Explorer III
Many times the pump suction pickup line does NOT reach to bottom of tank
Hence pump runs dry before tank is emptied
Several gallons of anti-freeze may end up being double what you would normally use.
And then you have bunch of anti-freeze you have to get rid of in fresh water tank and tank drain doesn;t allow complete drainage. So yiou fill,drain,fill drain, fill drain
Inherently Lazy---so am I
Use the 'winterizing' kit and SAVE yourself time, effort and more work then was necessary to begin with
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
