DutchmenSport
Oct 31, 2017Explorer
Old-Biscuit wrote:
Many times the pump suction pickup line does NOT reach to bottom of tank
Hence pump runs dry before tank is emptied
Several gallons of anti-freeze may end up being double what you would normally use.
And then you have bunch of anti-freeze you have to get rid of in fresh water tank and tank drain doesn;t allow complete drainage. So yiou fill,drain,fill drain, fill drain...
Not to mention, that bit of water that never completely empties or gets sucked out will dilute the RV antifreeze making it less effective, or even not effective at all.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
