papraw's avatar
papraw
anti lock brakes on toad
Hi All
I have a chevy HHR as my toad. I use an SMI Delta force braking system. A few weeks back during a hard stopping situation the brakes locked up on my HHR flat spotting the front tires.
I am wondering why it wouldn't be possible to jumper a hot wire to the abs controller so it would operate while the ignition is in the accessory position? Which would in my opinion totally prevent another set of flat spotted tires.
Is anyone aware of this being done, or have any input on why it shouldn't be done?
  • Thanks to everybody for there replies. I pretty much figured it wouldn't be as simple as it seems on the surface.
    I think maybe I am being a little anal and trying to adjust the sensitivity to close to the brake application of the M/H. I have turned the sensitivity back a little bit.
    Didn't flat spot any tires on road trip this week.
  • Mandalay Parr wrote:
    Might Readjust the braking system so it doesn't apply the toad brakes too hard. I
    This
  • ScottG wrote:
    It would need more than just the ABS controller, it would need speed input (and probably more) from the puter and power to the ABS pump.
    If you powered up the vehicle enough to do all this, it would be racking miles as you tow as well.
    Pretty much was I was going to say. With todays computer controlled cars, there's all kinds of input to the BCM or Body Control Module and, the ECM or, Engine control module and even the TCM, Transmission Control Module. All those things work together on a second-by-second time frame. And this includes the ABS system. So, even if you could "Hotwire" the ABS system, you may be back feeding power to points it's not supposed to go. Just a few thoughts here.
    Scott
  • It would need more than just the ABS controller, it would need speed input (and probably more) from the puter and power to the ABS pump.
