eichacsj
Jun 03, 2016Explorer
No. Just keep running what you normally do. With today's ECM's they "learn" and it takes 2 - 3 tanks for it to balance back out, if you switch for a couple of tanks you will not get the results you are thinking about.
Also as said above, follow the MFG recommendations but as a note also stated above octane requirements go up depending on the compression ratio. You'll notice manuals with ratios around 10:1 or above generally requires premium.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
