mkirsch
Jun 07, 2016Nomad II
Sam Spade wrote:wwest wrote:
Just how does the computer adjust timing to prevent pre-ignition...??
It appears that we have at least one person here who understands the difference between "spark knock" and "pre-ignition".
Or not, because pre-ignition is not only a function of compression ratio but also a function of the temperature in the combustion chamber. A cold engine won't have pre-ignition, while an engine that's at operating temperature and/or being worked hard will.
If you reduce the temperature in the combustion chamber by adjusting the timing, you also affect the conditions under which pre-ignition can occur.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
