- Winged_OneExplorer
tbolt2000 wrote:
Are there any benefit to running octane gas when towing? I had heard when towing use high octane gas.
Those days are gone.
I had a 70 Plymouth (liked high octane) that I decided to try a little mid grade in, just to see. Dear lord, you would think I put a bucket of screws down the carb's throat, for the fit it was throwing. Racing gas raised the octane enough not to kill the car.
You will know if you are running too little octane. - fla-gypsyExplorerNot unless the maker requires it in which case you bought the wrong truck IMO.
- LynnmorExplorer II
drsteve wrote:
No. Computer controlled engines adjust their spark timing to eliminate preignition under heavy load.
That's true, but it can't adjust the compression ratio. Knocking can be caused by other factors besides spark timing. Ford recommends premium fuel for the little Eco-Boost engine due to the very high cylinder pressures. - Mark_KovalskyExplorerYou don't need higher octane in high altitude. The mean effective pressure in the cylinder is lower due to the lower density air, so you actually can use lower octane fuel. That's why the octane ratings at the gas stations at high altitude are lower than at sea level.
- icanonExplorerI use what the manufacture suggests. Only time I use a higher octane is when I know I'm driving in high altitude.
- drsteveExplorerNo. Computer controlled engines adjust their spark timing to eliminate preignition under heavy load.
- camp-n-familyExplorerMy manual "suggests" higher octane when towing. I've tried both and haven't found the extra expense was worth it. No real noticeable difference in power or mpg.
- 2oldmanExplorer IIno
- Sam_SpadeExplorer
downtheroad wrote:
Use what the manufacturer calls for in the manual.
This. If you are on the ragged edge of needing higher octane gas your engine will TELL you so with a pinging or knocking sound under load. There is NO other reason to pay for octane that you don't need. - downtheroadExplorerUse what the manufacturer calls for in the manual.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
