imgoin4it
Aug 08, 2018Explorer
I had one on my coach for one year. On air conditioning it was fantastic. Quiet, lots of air flow and per my RV tech is rated for 15,000 BTU, but actually closer to 18,000. Had it taken off because it was also a heat pump. As for heat pump it was totally useless. Would run, make heat,, then shut off. It abdolutely would not raise the temperature in the coach, not even one degree. Several others had the same experience at that same time. That was a year ago. It was working exactly as Dometic said it was supposed to. That was NOT when it came to heat. Not sure if Dometic has fixed it. If you don’t care for heat it will be great.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
