jolvi
Aug 10, 2018Explorer
Bob Vaughn wrote:jolvi wrote:Bob Vaughn wrote:
I REPLACED MY DOMETIC WITH AN ATWOOD AIRCOMMAND HEAT PUMP AND I HATE HATE HATE IT....IT DOES NOT WORK AS ADVERTISED AND ATWOOD WILL NOT FIX IT.....SO DO NOT BUY ONE....
Could you be more specific? I am wondering what the issue is heat pumps only good to about 40 degrees, cooling is efficient, air flow is great, quieter than the Dometic Brisk Air II it replaced and then again Dometic did buy them so all in the same basket now.
Mine will not heat the rv even at 50-55 degrees outside...
I have had two homes with heat pumps and did have Atwood with heat pump on motor home. The deal is from what I understood is that if you want temp at 70 degrees that is what they put out no higher so there is never a blast of hot air which most heating appliances put out. We dis stay in Alabama at 27 degrees set temp at 65 degrees and it did keep it comfortable di1d use furnace to heat it to 70 though.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
