hunter_rv's avatar
hunter_rv
Any experiences with portable AC units?
I am completely off grid and currently have 2 generators (Honda 2000i and 7000i). I only want to bring out the out the big one for prolong cooling periods and also don't want put the hours on the big one unless absolutely necessary.
Researching the possibly of using one of these portable ac units (between 8.8 -12 amps) as an occasional use ac unit, instead of the 12.5/15k BTU units on the 5th wheel.
Does any one have any experience with this units and also describe how you are venting the unit?
...editing for additional info
this is private land and I do use this as a camp. I am just now starting into solar/wind, but based on info I learned on this site and YouTube, I need a large size set up just for this small size portable unit. So I want to use the small honda 2000 up until the time I really need the run the 15k BTU unit-then I haul the 7000 in. Since it is so big and expensive, it is kept at my house and loaded up on a Kawasaki mule for the transport on the back of the pickup truck. I want to keep the hours low to ensure that this lasts many, many years. The power company quoted we 35k to run power to the site due to the distance and terrain- so I use generators until I can build up solar/wind.
Ideally, I think I can by with a small portable unit 8k BTU, 8.8 amp draw for the bedroom space only.
Thank you.
