time2roll
Mar 16, 2014Nomad
Lyrikz wrote:Connect the main power at each end of the stack and you should be fine.
There is nothing wrong with using 4 12 volt batteries wired in parallel correct???
i figure i cant return them, might as well get some good use out of them...
Above pic shows a good example where the negative lead is extended to the other end of the stack.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
