enblethen
Feb 16, 2014Nomad
You need to keep the tank clean. They start to chip from road debris. You should re-paint it when it gets nasty looking. There is Krylon propane tank paint at my local Ace Hardware.
Make sure the valve and fill protector shield is straight to gain access to those items.
There is a device call extended-A stay that allows connection of an external tank. The kit comes with a high pressure hose for connecting the tank and a high pressure hose for BBQ. It mounts between the tank valve and your existing regulator.
You would need to check what type of propane source your rig is plumbed for. Most are plumbed for low pressure.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 06, 2026
