dcason's avatar
dcason
Any maintenance needed on propane tanks?
Just asking because I thought I read there should be but hubby doesn't do anything and being that this is flammable stuff we are playing with I thought I should ask.
Donna
Oh, we have the internal kind in a class C.
Also, can we add an auxillary tank with a tube to the outside so
that we have more propane in Canada...there is a bbq grill gas
hook up there already. We want to add a 20 lb. tank. Do we
need a switch or something to switch from internal tank to outside
tank?
  • Bumpyroad wrote:
    just guessing here but I would think your bbq hook up is low pressure and any external tank you add would need a regulator to drop the pressure?
    bumpy
    That's what I'm thinking.
    Bruce
  • No maintenance require other than normal cleaning and wiping, Look at it every once in a while for damage to the valve hoses and regulator.
  • just guessing here but I would think your bbq hook up is low pressure and any external tank you add would need a regulator to drop the pressure?
    bumpy
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 14, 2026
