Crdodd's avatar
Crdodd
Any problems with plugged tires
Greetings All,
I have a slow leak in one of my trailer tires. We have a short trip planned for the 4th, so I need to get the repair done. Prior to this, i have had a blowout, and i have replaced tires, but i have never had a leak needing eepair. I was just wondering if there are any additional concerns with a plugged tire?
Thanks for the replies.
Charles
  • patched from the inside your good to travel, don,t let them just plug it. and while your looking for that leak check the rubber insert for leaks , there known for rotting away.
  • I'd either plug it or have it patched on the inside. Then I wouldn't worry about it until it becomes worn out.
  • Plugs for temporary patch only in tire tread. Use patch on the inside of tire.
    No repairs in sidewall area.
  • I have not found the leak yet, but I am assuming it is in the tread. If it is a problem with the sidewall, I plan on replacing the tire.
    Thanks.
  • Plug in the tread or sidewall? If sidewall, I'd replace the tire. In the tread, I'd use it until it needed replaced just like the rest of the tires.
    Opinions will differe and YMMV.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
