pullin2 wrote:
I have used three different hitches on the same truck/trailer combo, so I can give you a side-by-side I think.  All the hitches performed their weight distributing function just fine, but varied a lot in their ability to control sway.
In order (from worst to best):
1. Equa-lizer.  This is what the dealer supplied, and it did very little to handle sway.  Big trucks and wind gusts made for a lot of white-knuckle travel.  A lot of folks swear by this type, but I didn't like it.  I actually moved it to my boat trailer and it worked much better (more on this below).
2. Regular trunnion bar and chain setup, with friction sway control.  I tried this version and it had a better ride than the Equalizer, and after adding a second sway controller it handled sway a little better.  I still didn't like it when being passed by semis on the highway.
3. Hensley Arrow.  Yep -- I've downed the Koolaid and joined the cult.  The absolute best hitch I've ever had.  Period.  End of story.  This one solved all the sway problems and is as easy as the Equalizer to hook up.
More about sway.  I'm pulling a V-nose Windjammer (35 feet) and I believe there may be something unique to that shape that makes them more susceptible to sway and wind effects.  Or maybe it's just some weird emergent effects based on my particular truck/trailer combo.  I have a really big (30') boat, and the Equalizer works great for it.
I think a lot of the flat front trailers actually provide a little bit of down force on the tongue (if towed slightly nose down) at speed because there is always some slope to deflect air up and over the trailer. V noses do not have this. You might try towing nose down a bit more.
