westend
Mar 25, 2015Explorer
If you can get away from hose clamps, that would be one upgrade. A manifold sounds like a lot of work since an RV usually has one hot and one cold supply trunk. Increasing the number of supply lines and connections would only add more possible failure points.
If you have access to all the supply lines and have the inclination, upgrading the piping to PEX and connecting all with compression fittings might be a solution to having a somewhat fool proof system.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
