theoldwizard1
May 16, 2019Explorer II
GordonThree wrote:Old-Biscuit wrote:
Air????
How did air get in a used 1 lb propane bottle?
When its empty and connected to an appliance with the valve open?
It might not be "air", it might be propane "vapor". The bottom line is you want to put as much LIQUID propane into your cylinder as is reasonable.
Segue - connecting a hose between and empty and a full 20 lb tank will result in two tanks half full. They will "equalize". The simple solution is to use a hose that is long enough that full bottle can be placed in the sunshine and other in the shade or better yet in a container of cold water. 10-20F will cause enough difference in pressure that, over 30-60 (?) minutes the empty one will be mostly full.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
