kyledub's avatar
kyledub
Anyone pulled over by CHP?
Question- I searched various forums with not many answers. If hypothetically; I were to get pulled over by CHP to verify my trailer weight, what number would they check? The max GVWR? The reason I am asking, is am going to buy a bigger trailer for the growing family. I want to keep my current license and get the RV 15000 max endorsement (CA). So do I shop for a trailer with a sticker @ 15000 or something less? I can't see CHP telling you to drive to the scales to get a actual weight?
  • You'd have a better chance of getting pulled over for speeding. My FIL was pulling his 5er and was doing 65 down a slight grade. Got a ticket for $400
  • If hypothetically; I were to get pulled over by CHP to verify my trailer weight, what number would they check? The max GVWR?
    You will have as much of a chance of CHP or any LEO anywhere stopping a RV "just for a weight check" as you will have a rich uncle leave you a million bucks.
    CHP or DOT doesn't use a vehicle GVWR for how much load the truck can carry. What they do check is tire and axle ratings.
    This from a RV.net member (I think) who had the same question for CHP.
    Its long and I snipped for length;
    The California Vehicle Code (CVC) does not contain a law that
    specifically limits the amount of weight a vehicle may tow based on the
    towing vehicle GVWR or GCWR. There are, however, laws that limit the
    amount a vehicle may tow based on other criteria.
    Title 13 California Code of Regulations prohibits
    the loading of tires above the maximum load rating marked on the tire,
    or if unmarked the maximum load rating as specified in the applicable
    Federal Motor Vehicle Safety Standard, or in a publication furnished to
    the public by the tire manufacturer. This would most likely happen in
    the case of a pickup truck towing a large fifth wheel travel trailer, as
    those types of trailers tend to transfer a larger portion of their
    weight to the last axle of the towing unit causing that axle to exceed
    the tire load limits.*****
    I trust this has adequately answered your questions. Should you desire
    any further information, please contact Officer Ron Leimer, of my staff,
    at (916) 445-1865. Sincerely,
    S. B. DOWLING, Captain
    Commander
    Commercial Vehicle Section" *****
    So there you have it from the horses mouth. Just stay under the trucks axle/tire load ratings for how much load the truck your truck is carrying.
    If I was concerned with what any state DOT says about overloading I would check with them myself.
  • I'd be more concerned that truck can safely handle larger/heavier trailer vs CHP pulling over to weigh.
    Have you been across set of scales with current truck a;; camp ready to know what you have in regards to GVWR, AWRs and payload availability?
    Nothing worst then to buy a trailer and THEN find out it is overweight....
  • Probably the only time it might come into question would be in case of an accident. I remember years ago a fella I worked for was leaving a bar one night and drove his truck off the road. Next morning when he went to pull it out of the ditch he was ticketed for defective tires. Yea, they were bald, but that was not the cause.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
