Bumpyroad wrote:
FrankoToo wrote:
I have something like this.
https://www.amazon.com/Rainwave-RW-9FM-Digital-Water-Meter/dp/B007NHS9M4/ref=sr_1_5?crid=3TE0GGYK91RP4&dchild=1&keywords=garden+hose+water+flow+meter&qid=1616440300&sprefix=garden+hose+water+flo%2Caps%2C322&sr=8-5
I can see that of value only the first time you fill your empty tank. assuming it is 40 gal (or whatever) and you fill it with 39 gal, but then when you use some water, ??? gal, how do you know how much water is in the tank then? every RV I have owned had a translucent tank where the fill level was visible .
bumpy
The TT has a closed bottom and is insulated. So you can see no tank at all, translucent or otherwise.
