Grit_dog
Apr 07, 2021Trailblazer
I think you're trying to create a solution to a problem that doesn't exist.
4 quality spacers will run you about $300. You're probably needing 1" -1-1/2" spaces to set the offset the same, but might need a bit more given the wider rims as well.
Then you're running on spacers for what? So you can use your old 17" Dodge wheels on the trailer?
Or are you just looking to have an extra spare tire?
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
