Chuck_thehammer
Dec 07, 2017Explorer
if you do not NEED plus or minus 5 degrees..
for 20 dollars. go to a R/C (radio controlled) hobby shop... they work well...
used for the nitro/gas engines...
to compare one temp to another..
as for bearings... should be about 20 degrees above ambient air temperature...
tires.. 10 to 30 degrees above ambient air temperature.. but REMEMBER the Full SUN side might be another 20 degrees more...
I started out using one.. to quickly find a car engine mis-fire.... that exhaust tube will be cooler... then other engine problems... cooling .. ect.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
