hbillsmith
Oct 11, 2014Explorer
CAT provides special pricing for RV weighing. When you go thru the first time you simply tell them you are going to be doing additional "re-weighs". The way the process works is that after your first weigh you go in and get your assigned ticket number. Then when you get your second and third weighs just tell the operator that you are a re-weigh for ticket number xxxxxx. Reweighs are $3.00 I believe. My usual pay for 3 weighs including tax is about $18 total. Of course you need to do all 3 weighs the same day. I usually do it this way:
No.1 - Pull thru fully loaded, trailer attached with WD on.
No.2 - Pull thru fully loaded, disengage/remove the WDH.
No.3 - Drop the trailer in the truck parking lot and just weigh the fully loaded truck.
Final note: All the passenger stay in the truck, no getting out while dad weighs. Second, do it with full gas/diesel and propane tanks.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 19, 2026
