path1
Dec 18, 2014Explorer
Scale weights
Thanks again for all the input on previous post http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28109016.cfm
Here are the scale numbers and spec’s
Pick up (2001 Dodge 2500, 5.9 Cummins, 8 foot bed, SWD)
Front 3820 (GAWR 4500)
Rear 2860 (GAWR 6084)
Total 6680 (GVWR 8800)
Pick up and Trailer (Arctic Fox 25W, 2013 model)
Front 3720 (lost 100 pds?)
Rear 3780 (added 920 pds)
TT 7880 (Tandem axle, tires & rims max 2830 pds @ 80psi)
Added tongue weight to pick-up of 920 pds or 11.5% percent.
-Eaz lift (elite) weight dist hitch system (spec’s from manufacture)
Max Tongue weight 1000 pds (I’m OK, but getting close)
Max gross Trailer weight 10,000 pds (I’m OK)
-Receiver mounted on pick-up (spec’s taken from label)
Max tongue weight 1,000…. (I’m OK, but getting close)
Max weight 10,000… (I’m OK)
TT is level and running parallel to ground, along with weight bars.
Have not used TT enough to know how tanks will affect weights yet.
Will probably upgrade to better hitch system in future, but for right now I think I’m OK.
I think I'm OK, What do you think?
Thanks again.
Thanks again.
