rangerbait
Apr 23, 2015Explorer
Lantley wrote:
AS to weight your comparing 8" drop to PP adjustable. I imagine 8" is the largest HA stinger available and the PP is still heavier. Compare 2" drop or even a straight stinger and the weight disparity will be even greater.
Bottom line is the HA stinger is a heavy PIA to carry , but the PP adjustable is even heavier.
Not sure about others but I handled the stinger at least twice each trip. Sometimes more if I took it off at the CG. I do see the larger heavier PP adjustable stinger as a deal breaker simply because once set there is no need to having a larger stinger. Adjust-ability has minimal benefit to 95% of users because they tow with the same truck every time.
I can see how this might be an issue for some people, but it's simply not for me. What ultimately tipped the scales in my decision making was the tone of the respective companies...Hensley goes way more on the offensive then ProPride, and frankly, it's a turn off. While Sean certainly seems to have no qualms about mud slinging, it's almost entirely in response to Hensley claims.
