Hi jadatis;
jadatis wrote:
Once read for ST tires that for higher speed a percentage higher pressure then acording to the lists, and for better handling quality , also a percentage highening up.
If then the new pressure came above maxloadpressure, pressure needed for the maximum load , so reference-pressure, it may not be more then 10 psi.
So my calculation of 44psi + 10% =48,5 psi already has that percentage , wich I mean to remember 2 x 5% , higher then acording to the list,in this case my extra save list, and so stays under the 50+10 psi , and is allowed.
You are also allowed to drive with 60 psi , thoug it would not be good for grip and keeping the screws in the wood of the TT.
You can even stay at normal rubber valves, wich are allowed a cold pressure of 65 to 70 psi ( depending on the brand) with 26 psi extra for higher temperature in the tire, to the mildest american standard.
This 26 psi makes it possible to fill at 65dgr F a pressure of 70 psi and if the inside tire temperature gets boiling point of water ( 100dgr C/200dgrF?) , wich it can incidentialy get by the heat of the brakes, transported trough the rims, the pressure stays below that 96 psi.
High pressure snap in valves wich are alowed for 90 psi maximum cold pressure , or metal valves for over 150 psi.
Yes, I understand, and thank you again for those calculations.
Are your formulas are based on industry standards in Holland? I say that not to challenge, but only to say I must interpret the standard sent to me by Goodyear. As a member of the Tire and Rim Association, Inc., Goodyear is compelled to adhere to those standards in order to use the ST designation.
I base my calcs, the 60psi, on the phrase 'rated maximum load'. If Goodyear had said 'rated minimum load' per the tables, then your calcs would be within the Goodyear PBS #2011-13 which is meant to advise Goodyear dealers.
The issue is not clear yet.
HTH;
John
