enblethen
Jun 26, 2013Nomad
Some anodes use a steel wire to support the anode material.
Atwoods with an aluminum tank do not use anodes.
You maybe able to disolve some of the material to get to drain with CLR or maybe some Lemi-shine diswasher cleaner.
Remove pressure releif valve and pour in there.
You may even be able to drill a hole in the end of anode, then use an easy out to get it out. Don't put too much pressure on drill or it will fall inside the tank.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
