dfeyre
Jun 27, 2013Explorer
It is an anode rod and not a hot rod. It has the steel wire in the centre like all the aftermarket ones you see for sale at RV parts stores for Attwood water heaters. I have been squirting CLR around it and pulling on the steel wire with visegrips. It is in there so tight that the water doesn't even leak out. If the wire pulls out or breaks then I may try and drill.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
