Old-Biscuit
Jun 29, 2013Explorer III
IF this is in your 2003 model and is indeed an Atwood water heater it does NOT need an anode.
Just because items are available in the aftermarket doesn't always mean they are needed or good ideas!
The small drain hole (1/2" for Atwood) and an aluminum rod (collects deposits) make it difficult under good conditions to remove.
Now that you have it out..........give the inside of tank a good cleaning using a vinegar soak
Pour 4 gallons of white vinegar into tank via PRV
Turn water heater ON
Let it cycle thru 4 heating cycles
Then drain rinse flush repeatedly to get rid of the accumulated stuff on tank interior and electric element if so equipped.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
