phemmert
Mar 18, 2014Explorer
Atwood Gas Hot Water Heater and Access Door
I have a 2007 Lazy Daze with a 6 gallon Atwood electric ignition gas hot water heater that's worked flawlessly until this trip. Long story short, the heater will not re-ignite as needed when the outside access door is closed. When open, it works normally. When closed, the heater will work fine, until it needs to relight, then will only operate for a few seconds, then shut off. The red light on the interior panel comes on steady. I open the access door to the heater, turn off the master switch, turn back on, lights off, steady green light. All is good. A service tech told me that airflow access to the heater itself is the problem.
Nothing has changed with the coach. Why would airflow to the heater suddenly be an issue, or is something else amiss? Discovering this anomaly was amazing to begin with, but I'm puzzled why the issue crops up now, when everything else is equal. Air supply seems to be the culprit, but I have to think something else nefarious is at work.
Thoughts anyone?
Thoughts anyone?
