Hi,
How long since you cleaned the burner?
golfknut wrote:
I might add we have had the DSI fault light come on a few times over the past couple months.
We would just leave the water heater off for a few hours and then turn it back on and everything would run fine.....until the next time it happened.
Does this indicate a failing thermostat?
We didn't notice if the water was any hotter at these previous times. We didn't notice if there was water dripping out at these previous times either.
If the thermostat is stuck or not making good contact would replacing it fix the issue?
