time2roll
Oct 25, 2013Nomad
When the indicator turns from green to red the knob/dial/lever will be pointing at the empty tank. Move the knob/dial/lever to the other tank and go fill the empty.
Check every few days or once a week and you will never run out. Check daily if running the furnace a lot or other heavy usage.
If you tend to be forgetful then you can use the manual method stated above.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
