1L243's avatar
1L243
Explorer II
Dec 18, 2019
Awning Cost
Anybody have a idea of what it would cost to ad a 10' electric awning and installation? This would be in addition to the awning I already have. The channel for the vinyl fabric is already there.
  • We used Shade Pro to upgrade our worn manual awning to one with power actuation and aluminum weather shield, which was done in our driveway at a reasonable cost. If they are in your area you should check them out.
  • Before you start, do you know for a fact that there is framing or plates within the wall to mount the awning?
    Manual awnings were attached at floor level and didn't need attachment points half way up the wall.
  • We had a second awning installed on our 5er a year ago. We scheduled the work with our dealership. We also had some other warranty issues, and wanted a minor repair done.
    The biggest challenge for the dealership service department was how to run the wire to power the awning. And then, where to run the switches. We also had LED lights installed.
    They did a great job running the electric wires that powered everything, and everything went through the fuse box/converter too. Because we wanted the awning over the back door (which is on the opposite side of the trailer), we wanted the switches near the back door. They ended up putting the switches in a cabinet in the bedroom, but near the door and a window on that side too.
    The total price for the lights, the awning, the labor, and replacing the little amber porch light with a different LED light, because the awning interfered with the original light ran us about $2000.00
    Was it worth it? Absolutely YES! We use the back door on the opposite side as our main entry door a LOT more than the front door in the normal location.
    When camping, the normal front door is the "front". When home (and we use our 5er 24x7x365), the back door on the opposite side is the "front". The back door gets used a LOT more than the traditional front door. A lot!
    So, the price of the awning and lights was worth every penny for us.
    EDIT:
    FYI, the added 2nd awning is 16 foot long too.
  • This will give you a place to start looking:
    https://www.campingworld.com/outside-rv/awnings-canopies-shades/rv-awnings
    or
    Same link
    Good luck
    Lakeside
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
