philhyde's avatar
philhyde
Axle repair in Houston, TX?
Can anyone recommend a shop/service for axle repair in Houston, TX? Realistically, anything in Southeast TX would do the trick.
Thanks in advance.
  • Thank you for all of the replies!
    edbehnke wrote:
    just do a quick google.
    https://www.google.com.mx/search?q=rv+axle+repair+houston,+tx&ie=utf-8&oe=utf-8&gws_rd=cr&ei=QxXBVNLAMIakNq3lgoAH
    Well, I was looking for a specific recommendation. Not a listing.
    TucsonJim wrote:
    We need a little more info to get you hooked up with the right repair shop. What kind of vehicle do you need repaired? Trailer or Motorhome, and what make? If a trailer, is it a Lippert, Dexter or other brand of axle?
    TucsonJim - I have a Montana Mountaineer 5th wheel, and I'd like to have the current springs and axles replaced. The current axles are Dexter, which is what I would like to replace them with.
  • Try Master Hitch or Strouhals. Both have treated me well.
  • Try Husky Trailers in Houston.
    They supplied me, here in the valley, with an axle. w
    Worked very well, They may install or know of a shop that will.
  • We need a little more info to get you hooked up with the right repair shop. What kind of vehicle do you need repaired? Trailer or Motorhome, and what make? If a trailer, is it a Lippert, Dexter or other brand of axle?
  • just do a quick google.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
