I am looking at the spec sheet for my single axle 2008 Fun Finder X-160. Can someone please tell me what "Axle Weight (lbs.) 2043" means? Thanks! Regards, Michelle
If it's just"axle weight" that would be the weight on the axle when empty. If it's gross axle weight then it's the most you are allowed to place on the axles. If you overload then able damage can occur causing excessive our uneven tire wear.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
