Mik68 wrote:
Slownsy wrote:
Hi mike, hear a Honda 2000w inverter is around $1000 but no good to take to OZ. But u will get most of the money back when selling it.
Frank.
Hi again Frank, was wondering why an inverter ( is this the same as generator?) purchased in the US would be no good in Oz? I thought as it would be run on gas or diesel & charging batteries, it would be quite a universal piece of equipment?
Mik
Mik - I believe Slownsy just abbreviated the term "inverter/generator" to "inverter". Just to clarify:
An
inverter converts DC power to AC, and you can plug small ones into a cigarette lighter in your car or RV or you can wire big ones directly to the batteries. Some RVs have them built-in and many don't.
A
converter converts AC power to DC when you plug your RV into shore power and there is one permanently installed inside most RV's. This unit charges the batteries and converts the AC power to the DC signal required by most of the appliances that are inside the RV.
Some fancier RVs use a more expensive
"inverter/charger" for this purpose, instead of a simple converter. This is a device that charges the batteries AND converts DC power to AC. Generally,
5th wheels generally have a converter installed at the factory but no inverter or inverter/charger, although higher end units make them available as factory installed options.
Generators use fuel (gas, diesel or propane) to create AC power and you can plug your RV's shore power cord into one to supply power to your RV as if it were connected to hookups and to charge the batteries too.
Yamaha and Honda both make small generators which they call "inverter/generators" and these are powered by fuel and sized by the watts they produce in the same way a regular inverter is sized by wattage. They generate 120v AC power, and that's what was being referred to as a problem because these generators will work with N American made RVs that are designed to plug into 120v AC but won't work with Aussie made RVs that are designed to plug into 220v AC.
So the idea was to buy an inverter/geenrator in the US to use here and then sell it before you get to OZ since presumably no one in OZ would want a generator like that.
Also, if, when you get back to OZ, you replace the 120v AC->12vDC converter that is in your RV with one made for Australian RVs (one that converts 220v AC to 12v DC instead), then you'll be fine plugging into shore power in OZ.
The only other question would be -- are Aussie-built RVs designed to run on 12v DC or 24v DC? It might be worth checking with some RV service guys there to see what the DC appliances run on and how hard it would be to get parts/repair service for the 12v stuff in the rig...
I've got photos of inverters and converters and a general discussion of these things at the bottom of the page here:
RV solar power installation
