jeeperdude10 wrote:
I wrote Brake Buddy and response was that the newer vehicles do not carry proper amperage...which causes BB to shut down. Requests that I need a 'battery direct kit'...guess I will go back to my alligator clamps that I used on my '98 to keep from having to turn key to accessory. At least now I know...thanks for your opinions-right on track!!!
Thankful that it is not the unit itself.......whew!!
Before you do that plug it in and try ALL your cig lighter outlets.
My SUV has 3 cig lighters and only one would run the Brake Buddy. The other 2 did not. So some cars still have 'one' that is full power.
And I also found out you had to really push it in new openings seem to be tighter/narrower so the tip of the Brake Buddy doesn't make good contact.
